Thanks for the details Jake. I had a look at a Lectron and the only questionable part is the right side choke. I have the ~12L Clark tank and I doubt I could reach the right side choke. Lectron are currently working on a cable choke kit which should take care of this. A 45* cable fitting is essential for the carb top.
Jakobi; I have a 45 degree cable in it now. Ideally you'd trim back some of the sleeve on the cable so allow it to sit in lower and give a greater range of adjustment. [/QUOTE said:That's what I did. I cut off 16mm of the sleeve from the stock cable, and I haven't had any issues with it.
Heres a quick shot of the cable into the carb. Its very easy to pull this up which results in the slide lifting. Not sure where abouts on the cable I'm going to fit the tie wire, but should be easy enough to mount it back onto the adjuster on the carb.
The older lecterns do differ from the newer ones, not 100% sure if the differences but I do know that the needles are not interchangeable between the old and new and the old ones only allow needle adjustments of 1 full turn whe the new knew will do 1/4 turn increments. The new ones are definitely a better carb for the sort of riding we all do.
With the dimensions it should be possible to reduce the length by ~5mm with some minor machining to make it an easier fit. Will look into it if it becomes an issue.
Jake if you want I'll send a 3-2 needle to try... It'll have a richer bottom end and same mid range compared to the current 3-1 needle so you'll be able to drop it further to lean out the mid but avoid the hanging idle.
Got some video footage too. Give me a week and I'll be able to post some up. Cheers
Thanks Dave.
Today I put a solid 70kms on the bike with mixed terrain from tropical rainforest, humid, damp, exposed roots and ruts galore to dry sandy, rocky goat tracks, and all tied together with some flowing woopee trails. A fairly decent mix to get a grasp on it.
It feels to be a bit beefier in the mid range than my previous setup was. A bit more grunt just below band, which has also had the effect of smoothing the transition. Burbling off the bottom is very similar, however the Lectron feels it lacks punch right off idle. I'm going to go richer and see if I can get a bit more right off the bottom. The bike isn't bogging or missing, but just doesn't feel as punchy as it could be. Once up in the revs it runs like a champ!
Before I left I brought the power jet out another 1/8th of a turn which feels better than it was. After the first section of single track pulling a gear high and loading the engine up I had the old hanging idle again so went a quater of a turn richer on the rod. No more hanging idle for the rest of the day. It would smoke a bit in the slow going, but so would my AS2 with current jetting. I'm hoping that I can get another 1/4 to 1/2 a turn on the metering rod picking up some more torque without introducing too much burbling, or taking too much snap away from the midrange.
Fuel consmpution I have not checked yet but visually looking in the tank I can see a good quanitity floating around. I'm guessing I would have been on target and used about 6-7L for the 70kms of riding. I'll follow this up when I refill the tank.
Nice work.
Sent you the 3-2 needle today express post, hopefully be there in a couple of days. Will be interested to see if it sorts the low rpm running.
Cast SC is only a few weeks away now!![]()
