Skidad
Jeff Douglas from Nutech (TuBliss system developer) has passed along these new install tips for the system which will help prevent some potential issues. Thought I would pass them along to those using the system.
http://www.nuetech.com/
As an FYI.....This guy offers just outstanding customer service/support (besides a really cool product) and has gone out of his way every time I've had a question or needed something. He's right at the top of the list along with Kelly from Motosportz (steering dampers) and the guy from G2 throttle cam system for top customer support in my book.
Anyway, here are the new install tips he sent me.
FYI, we are currently updating the instructions, with TWO major points (just thought I would share this as it might be helpful!).
1. When installing the red liner onto the rim. It is best to start pulling it onto the rim at the rim lock, working your way around to finish back at the rim lock. About 1/2 way around it starts to get tight & at this point is where you can pinch it together and work it into the drop center of the rim to create a LOT more slack so it will go on the rest of the way with minimal effort. Do NOT finish opposite of the rim lock as this will damage the casing every time.
2. We have also changed the RIM LOCK tightening sequence. It REALLY helps to only finger tighten the nut so just a thread or two are showing above it - THEN inflate the inner liner and tire and LASTLY torque the rim lock to 11 ft. lbs. This EXPECIALLY help with the fronts sealing on the first try.
Hope this helps and PLEASE let us know if any questions or if you have ANY other feedback.
