IMS makes a "pro series" and a "super stock" - I would recommend the pro series - they provide much better grip.
If you like a really wide peg the 09 YZ450F stock pegs are nice and the price isn't too bad either. These pegs will also set a little lower than the stock pegs.
I have the moose hybrid pegs on mine with the rear offset....the outer teeth were way to aggressive so I ground them down...they feel nice now
the brake pedal side is a bone of contention...you cant grind it enough...I will have to add some material there...MIG or drill a hole and add a cap screw
otherwise they are well made(maybe too well made..the stockers folded up like candy in a crash and saved the frame..keep that in mind)
not the best pic but...
I have also just added the hybrids after bending one of my pegs. i did not get the off set ones and think i need to raise my gear lever. I also found the outside teeth too extreme for off-road riding (may be ok for mx where you not putting your feet down) - they made my brand new sg12's look v second hand!- I have ground down the outside teeth (not as much as you have though) but need to g for a test ride to see if i need to grind more down and also filed out a groove on the brake side so that it can fold back more, but it still hits the brake pedal, don't think i can grind much more off.
Please explain what you mean by "MIG or drill a hole and add a cap screw"
You can grind all day long and the integrity of the peg will be gone by the time you is done.....the trick is to add some material to the contact stub on the peg.....I will do it this weekend....a blob of weld will work...but a small drilled hole 6mm..you can tap it and thread in a short 6mm bolt
Matt did you crash on the right side ??? Curious
So they just drop right in without grinding or modification?FYI-I ended up buying the new Talon YZ/WR Pegs, they bolt straight on and are a fantastic piece of kit.
