ninetenseven
Hi all,
I have a EC 300 2019. Was running fine, until suddenly bogged down, like i hit the killswitch. It didn't start anymore.
Noticed that with a long press on the starter button, it has a very weak and inconsistent spark.
I followed some other threads about this issue and managed to diagnose:
Coil readings OK (per manual)
Sparkplug cap OK (per manual)
Stator OK (per manual) also took it out to a visual inspection, everything looked good and healthy
Killswitch OK
Ground wiring OK
All connections are free of corrosion
All connections seem fine, with no visible issue
Now i'm leaning towards a failed CDI.
The sticker on the CDI is too worn out to read, but it should be the early version (2 maps).
Any advice or experience?
Killswitch OK
Ground wiring OK
