So, I turn 60 this year. I've never marked a decade milestone, so I was thinking new bike. I came up with this idea while returning from riding Moab with my daughters in December.
Looked at TM, Beta, Sherco, Yamaha (250x), but after some reality checking (too nice for me to drop on the rocks), I decided to stick with the 2002 EC300. Boy, the TMs are pretty.
So, here's what i did.
1. Repaired a hack frame repair (footpegs) I did about 10 years ago. Silver paint over the new 10 gauge steel welded in place looks very close to the nickle plating of the frame. Re-used a yamaha footpeg bracket which was the basis of the first repair.
2. New piston (after 440 hours) and cylinder re-plate. Most of the time spent was at low RPM riding behind my daughters until they became fast, and then they'd go ahead, and then i'd ride at medium RPM, low load. Rings were good, piston looked great, but the wrist pin did have a bit of a notch where the bearing rode. Cylinder had just a lip at the top, so it was time. Modern synthetic lubricants are pretty amazing. The small end of the con rod had a tiny bit of polish, and the big end and main bearings were tight. No need to tear that apart. I sort of wanted to, but really no need. Just a new piston kit and small-end bearing.
Also cleaned the powervalve hardware, and installed new bearings.
3. New ARC levers.
4. New ebay radiators and AS3 hoses. They fit, hold about 500 cc more coolant, but took some time to make right. $84 for a pair is a deal. CRD rad guards worked, too. The only weirdness is that the left radiator is located further forward than the right. i had to adjust the steering stop a bit to keep the fork tube from contacting the radiator.
The new radiators won't work with stock rad cap, so i bought the rad cap with the built-in thermometer. I can't read the TrailTech with my old man eyes, so this will be good.
5. New brake rotors and pads. Bought GG rotors. Replaced original rotors! Both were at their service limit, so i replaced them.
6. New front & rear brake lines, and new clutch line. New speed bleeder for the clutch slave cylinder. I hate bleeding the clutch with the stock bleeder.
7. Bought spare clutch MC rebuild kit, slave rebuild kit, and clutch pack (DP) just in case. Bike is on original parts right now.
8. Disassembled and lubed suspension - first time ever it didn't need a full bearing/bushing replacement. (I had done the suspension in 2019 when I installed the transformation kit. )
9. New tall Guts racing seat cover and foam. I used the stock seat foam and cover which came with the transformation kit, but i prefer tall seats.
10. New Dunlop Geomax EN91 tires and motion pro composite rim locks. (I had forgotten that I had Talon Rim Locks in the bike. My daughter's KTM needed new rim locks, so i am going to give her the Talon rim locks).
11. Aluminum kick stand from a 2005. Frame tab was welded in a weird way, so i made a spacer, and fixed the lean angle. No more tip-over siestas!
That's about it. I put about $1,400 into it, but it should be good for a while.
I have a two-month plan to ride this summer ('Rona willing) with my brother and daughters. Lost one of my two jobs last April (not a problem), which frees up summers. I realized that I've spent more time on this planet than i have left, so it's time to have some fun.
Thanks to Neil and Lauren at motocenterAZ.com for their help with parts. I was able to source everything i needed from them. Mark Berg said that bikes from 2000 on would be supported, and I can attest that parts availability was not a problem.
Long live legacy GG / Reiju Enduros.
