what forks to use
Good work mate! I'll be revalving mine before they go on. Got a few weeks up my sleeve yet.
Gosh I never reported back, mainly as life and nasty injury stopped me riding for a while.
Got the YZ forks revalved by local K-Tech chap here to the club rider MX & enduro spec.
Revelation. Or should that be Revalvation? But ssoo much better than yz valving for our rough terrain. Just much much better and leagues better than marzoccis even after revalve. Don't feel so beat up after a ride.
Hmm, well I've plunged ahead. Here are the spacers I've turned up to go from the 25mm GG axle to the 20mm YZ one:
The bearings from old GG & the only ones that are commonly available for a 42x20 size are 12mm wide (6004) as opposed to the skinny 9mm ones for the 25mm axle. This means the seal will poke out about 3mm which I suppose should be ok.
I've just roughed the outer spacers a little oversize and will skim the last mm or so once I have it ready to bold together with the wheel & clamps. I will then take the final skim from the outer to leave the lip that retains them in the seal (can't hold onto the spacer to cut it down if I do that first).
Then I just have to push out the steering races out (the bearing was indeed past it) and I'm dropping off the triple to my weldy guy. He has some thick plate ally I believe, will post pics when done. Will bolt up from bottom & be tacked to the old stops.
Hi F5
Are you able to share the final dimensions of the axle spacers you made up?
I'm procrastinating on the same route and may also use the older GG bearings in my 09 wheel as an easy way to adapt to the 20mm YZ axle.
Well. . . Icould pop ddownstairs, prop the front up and take the axle out. . . but if there are any changes between 2006 yz clamps and whatever you have plus the 07gg front wheel and bearings I used then it would be putting you crook.
Its real easy to do the change, use the oversize gg spacers and add a washer or two to get the wheel in the middle from the butside of the axle. Measure from rim to fork and on other side. You can then add spacer to the other side and measure gap to thick part of axle. Then recreate in proper size id spacer.
Remember the floating section of the axle means you have a little leeway as long as you clamp that side up after nut is tight and bounce on it.
Oh, alright. Make em both 22mm.
My floating side is actually 24mm but the axle isn't quite flush on the outside floating side. About 2mm. Its the nut side that's critical.
I should really cut the 24 down to 22 in case I ever swap them by mistake.
Thanks mate. Your description is just as valuable as the measurements and gives me some good guidance, especially the criticality of the nut side
Tag for reference to an ongoing fork swap project.
Sure is nice to have access to my own machine shop for this kind of work. :cool:
