Just as I thought, you have a Boyeseen RAD valve. All RAD valves are integrated reed block/manifold. Also, many take the same replacement reeds, and are all the two petal type. I know for a fact the CR250 RAD and OEM GG reeds are the same size. In fact the entire RAD valve is almost the same with the GG having a more acute spigot angle.
So what you did is order replacement reeds for a YZ with a STOCK reed block, not a RAD valve.
