Looks Great!!!
I too installed my new pump cover from Mark - Thanks!!
I also took the checkpoint impeller and modified it so that it was basically the same as the OEM one. Except IMO I think it will move more coolant.
For proper install I pulled the right side cover all the way off.
Which I was glad I did as 1 (dowel pin at water pump) of the 2 dowell pins was a bit rusty.
Cleaned that all up with dremel and filled with anti-seeze.
I then spray painted the inside of the new cover black.
Installed my modified checkpoint impelller....it was hitting just a bit.
Took the water pump cover off again and cleaned up the impeller where it had black paint on it.
Checked it again.
All clear.
Removed all paint with brake cleaner.
Reinstalled side cover (did not have to replace gasket).
So far good.....
