Hi Mr quick, can I ask what brand of gear oil you used?
Thanks
Hi I am using Castrol edge 5/30
Thanks
Power valve noise on decents and when trundling along road sections, so I have striped the power valve out and found alot of sideways movement so I made a stainless shim, placed it on the water pump side of the barrel, I basically halved the play in the valve and boy what a difference its made its quiet as a mouse now...
A while back I had the same rattle on decents/overrun and found side to side play in the power valve, I too fixed it by adding a shim each side. Interesting you had the same issue on a new(ish) bike, I thought it was just because mine is a well used 2004 bike.
Sounds great... although surely reducing compression ratio = less power?
It's a CMT guard. I have one for sale on eBay in the UK as I don't have my EC300 any more.
https://trialendurodirect.com/product/cmt-carbon-exhaust-guard-gas-gas-ec-2018-2019/?doing_wp_cron=1563923006.5735409259796142578125
   Thanks for the reply Rudolf
Could you shoot me a PM with a link to yours? Would you send to OZ? Will you pull from auction to sell?
If you give us your location/altitude/temperature then Jakobi might be kind enough to suggest a starting point for jetting, to give you a head start.
The standard no.7 slide is usually OK, so it"s a matter of trying different needles, main jets, pilot jets and clip positions. Most important to just make one change at a time, then test and keep notes so you don't get lost.
Make sure you're using a good quality full synthetic oil mixed at 50:1 (usually 50:1 but please check).
If you speak to your dealer (where you've just spent thousands) I would hope they'd help you out with supplying jets/needles at a discounted price! I wish GasGas and other manufacturers supplied a selection of jets/needles with their bikes.
Congratulations on your new bike, it looks stunning, I'm very jealous!
