Arrow Pipe--GROUP BUY!!
i thought id add how funny it is everyone always notices other stuff on your bike or in your garage eh? i do the same thing everytime i look at pics!
ya mine said right on the fedex slip classifying it as "customs fees" usually its brokerage fees
Finally picked my pipe up, Customs charged me HST on entry into Canada, no duty... So total cost was $259 + $16 shipping + $25 tax... Oh. Have to add the $60 I lost at the casino while in the states.. Lol..
Pipe sure is thin, will install tomorrow to see the difference....
Ed...
I gave mine to a friend in exchange for a new gnarly, I knew I would have crushed that pipe the first ride out on the right side so I thought I'd stick with what I know and what has held up for me in the past.
That's a bummer !! Too bad when you get some new bling it doesn't work out. Looks like Arrow had a good idea with the clearance of the pipe, but I guess it's a case of making it work better in one area and end up sacrificing in another area.
My forks will be back in a week. Then I'll post a report.
I have put a thick aluminum Moose guard spaced off the pipe by a couple of 1/8" thick strips of high temp silicone rubber. I'll let you all know how we'll that protects.
Spoke to the aussie importer in new castle at the superx last night and he seemed not even close to interested in getting it and also said it would be 600 bucks or 1200 for the whole system.
I Like It!
Finally got a quick ride with the Arrow bolted on. Pulls noticeably stronger in the mid-range. Which is nice because that's where I live. Since I rarely wind out the 300, I can't really say if there is an improvement in over-rev. She's always had good low end grunt, and I didn't notice anything lacking there.
I'll say its a definite improvement over stock for the way I ride. It remains to be seen how well the pipe holds up under my abuse.
I now have a couple more rides on the Arrow. I stand by my first assessment: Better mid-range than stock.
Since the Arrow was such a dramatic change in pipe shape, I was worried that it was going to change the power-band dramatically as well. This is not the case. Same smooth, linear, rideable power-band that I've always enjoyed.
First, I have to describe my normal type of riding as well as my style.
Type: Fast flowing single track trail. Some technical sections, an occasional long gnarly technical hill, long rocky sections with loose softball size to soccer ball size rocks. In these rocks, there is no rock avoidance. They are rock on rock, so only the big ones can be avoided.
Riding Style: Rekluse and LHRB. I go fast by spending most of my time in the mid-range of 3rd and 4th gear. I keep my momentum up and avoid the cut and thrust of braking and gassing. I try to ride smoooooth.
Throttle control is my mantra.
Zen is my right wrist at one with each knob of my rear tire...
Specific description of the Arrow's "better" mid-range: I find I shift less. Simple as that. I can be just a tad too low on the RPM and not need to shift down where I would have had too with the stock pipe. It's not that I'm riding a gear taller everywhere; I'm riding a gear taller more often.
Due to my Rekluse and LHRB, I don't have a clutch lever to fan when I'm slightly down from optimum on the RPM. So if the throttle won't bring it back quick enough for me, I have to shift down to rev her. Then I quickly shift up to drop back into the middle of the power-band. With the Arrow, throttle will get it back into the meat of the power band at times that I would have had to down shift.
Put another way, the torque curve feels like it starts climbing a little earlier than with the stock pipe. IE.: The mid-range has been broadened to the left.
So far,(aside from the initial dings) the pipe is holding up well.
I have scratched to coating off on the right side. There is absolutely NO signs of rust on this pipe. Even after I rode a mud race, let the bike sit for 4 days before washing it.
I pancaked my ARROW pipe pretty bad. I don't recall ever hiting anything big.:mad:
I bought the amoured DEP pipe. That turned into a fiasco.
So, I bolted up my throw down stock pipe.
Stock pipe has more low end torque.
The ARROW revs faster and pulls longer.
Bummer to hear of the damage.
So far I've been very happy with the durability of my Arrow. I do have it armored up like a tank, though.
I have two mangled ARROWs.
The 2nd one had a universal aluminum guard on it.
We have a lot of trail trash, made up of small logs and branches fom fallen trees. The get kicked up by the front wheel.
