19brendan81
Re pipes - my bike has the nickel plated pipe on it. Does that mean there is no catalytic converter welded inside?
I notice that if you tap my pipe with a spanner, it makes a 'thud thud thud' noise, whereas if you tap the stock pipe on my mates YZ it makes a 'ting ting ting' noise. I had always assumed there was an extra lining inside there.
Re the compression tester - im pretty sure it is accurate. I have used it on other things (cars, other bikes, chainsaws) and it reads as expected. The most recent example of this was when I was rebuilding a Mini 1000 motor and it read 160psi on each cylinder which what I was expecting.
I will test my bike again once I have done the reeds, as if these were leaking (which they are) it would effect compression to a degree...not sure if it would effect it to the extent of losing 40 psi though. If I cant get the compression up...would you say that 120psi is too low? It seems very low to me.
