Gas Gas 2012 Six Days
WOW!!! I don't care if it's got a cable clutch that I need to pull with my teeth I'm getting one! Thanks for posting it up.
It is almost every day that I kick myself in the ass for taking French instead of Spanish. Nobody knew.:rolleyes:
Nice looking machine. Send me a dozen.
Very nice. Looks great new but I'm not sold on white in general. I can see the new linkage, and what looks like could be the black plastic skid plate from the hard parts catalog. Yeah, Sachs 48mm? Likely typo or incorrect early info. Still 45mm Shivers on the 250F.
The white frame is OK, I had a white frame Husky. Its the white plastic that gets old fast. A good application for some clear vinyl or that Racer's Tape Jeff posted a link too(which, BTW, is expensive:eek:). Girard, how is yours holding up in that red dirt you have down there? I must admit I'm getting a bit bored with red, but it sure does hold up well.
Trivia question:
How recently has GG used/stopped using AJP hubs?
Perhaps this is related to the move away from AJP clutch?
What kind of hubs are on this?
And what hubs are on that 2011 Nambotin 300? Sexy.
Can anyone explain the new linkage design?
The translated page says,
New system of rods with more progressive.
New Sachs rear shock absorber with improved cooling capacity.
Regulation of spring preload, high and low speed compression and extension.
AZRickD, Clay actually got an answer to this question for us. See post #18 in the thread "2011 Nambotin (video)." LOL I would have quoted it for ya but I don't know how!
Here was Txomin's reply on the linkage change:
Progression curve is more progressive like soft in the first parts of stroke and hard on the final parts
This will give more comfort and traction and less stress on bottom
Stroke comparison on shock is 125 mm for the old and 130 mm for the new (this give better control on the shock speed and more reliable shock)
Lenght of the shock is 427 mm for the old and 449 mm for the new (this increase the volume of oil and the distance between the two support of the piston to get better reliability on the shock)
Rear wheel stroke is 290 mm for the old and 300 mm for the new (this give better comfort on big jump)
Assembly system of the full link is made with better sealing component to decrease the necessity of maintenance (old one made by OR and new one made by sealing ring)
Clay
Still in spanglish, but you get the idea :p
Basically it means that the progression curve is steeper, that is it will get stiffer faster. I guess the fast guys thought this was the way to go. Only thing that bothers me about this, being a rock crawler, is the hardware is a bit lower, a lot like a new Husky. I occasionally hit the current setup, but its no big deal as its bullet proof as we know. Hope this is the same.
I read the spanglish translation to read that it is both softer in the beginning and then rises to a mo stiffer mechanism toward the end.
Potentially better for both worlds.
