No advice for the shift drum, sorry.
Lay the case gaskets up against the left and then the right side case to be safe. They may have minor differences for some minuscule changes made over the years and you should be able to detect them if they exist.
The cylinder base gaskets can be stacked to make your squish gap larger or smaller. Now is as good a time as any to get your squish measurements. You'll need 3mm solder. Off the top of my head, 1.25 or 1.3mm is what you're supposed to shoot for - verify this. Yes this is a lot of installing and uninstalling of parts. Gaskets alone seldom get you to the desired measurement, but do what you can with what you've got. I didn't do mine when I put a new cylinder and head on and in retrospect this was a potentially dangerous choice.
