Hey guys
I have recently bought a secondhand 2007 Gas Gas ec 300. When I first rode it I was pretty unimpressed with the lack of power. I mean this is a 300 cc 2 stroke and I can't even pop a wheelie with it. When I reach higher RPM's the bike sounds similar to a 4 stroke. And I seem to have more power when I use 3/4 throttle rather than full throttle. Is this bike supposed to be under powered or is it supposed to be a real bullet?
Here is what I can explain a little better. When I ride the bike I don't get that surge of power that all 2 strokes have, its as if the "power band" doesn't kick in. Their is no sudden burst of power, but more of a continuous "lack thereof power". I have been advised that it is the power valve stuck or that I have clogged Jets.
I have tried the following so far to try fix the problem. I removed the entire Carb today and cleaned it out with a toothbrush and petrol. Petrol looked more like oil when I was done cleaning it haha. I changed the spark plug, cleaned the air filter and removed the Petrol out the tank and replaced with a new tank, using a 50:1 ratio. But the bike is still the same. No power band kicking in.
Does anyone have any ideas what could be the problem with it? I live in South Africa and Gas Gas is not a big bike here at all. 9 out of 10 bike shops won't even look at the bike due to a problem sourcing spares. If I know what the problem is I can get a bike mechanic to have a look at it and just order parts of an online shop.
I am a student so I am looking for the cheapest way to fix this.
If you need any more info just shout.
Regards
Jarrod
Regards
Jarrod
