it just won't pull anymore, no mis, no power loss like fuel, it just won't pull past 7grand in 5 or 6th. I think that I have the 172 jet in it, filter is clean. plug looked good, real good, tried a brand new one same results. No pull after 7000rpm.
Rob
you should be able to move pv easily by hand, but you will need to disconnect pv actuator rod, or you'll dislodge the balls.
i definitely dislodged my balls sunday when i broke my frame and subframe on a hillclimbOMG!!! Maybe I dislodged my balls!!!![]()
Well, this took a sad, sad turn
Say, when I disconnect the actuator rod, do I just undo the little nut?
Stupid question, how does the little nut on the rod come off, it just spins?
Do I remove the triangle first?
just sitting there, looks like I have almost 1/4 inch of free play in the rod. Is this the slack that they talk about in other threads that needs to be removed?
Thanks,
rob
You should just remove the tiny nut thats there, yes.
It is threaded onto a stud that is supposed to be tacked to that plate, but its not uncommon for it to break the weld before the nut comes off, in which case you will need to remove that plate in order to grab the stud to get the nut off. When this happened on one of my bikes, we tapped a thread where the stud passes through, locktited a cap screw in, and use a nylock nut so it doesnt need to be done up so damn tight
Yes, thats the free play that everyone talks about, the whole mechanism just kind of floats around before being under any tension from the pv rod, the plate should rest on the bolt.
See if I have this right, you tapped the hole, ran a screw through from the back side with loctite and then put a small nylock on the outside where it should be.... that translate right?
Yea, haha. Tapped the hole so the cap screw we put in did the same thing as the stud.
However, be careful with your taps because the remaining tack weld snapped a few of our taps
The picture looks like its not even attached to the plate?
Did the stud snap off and its now just floating there held onto the rod with that nut?
EDIT, im pretty sure the stud has snapped but a portion is still tacked to the plate, because you cant see the bearing through the hole
