You've been given much advice munch. No one will really be able to recommend you a needle because you haven't confirmed any details such as:
Model of carb (AS1 or 2) - Suspect AS1 given its an 06 250.
Slide number (and if it has a notch cut in it).
Have you set the float height? The magic number depends on the model of carb. See above.
The fuel overflow issue - have you determined if it is the float height or the Viton tipped needle valve? You won't have success if the engine is intermittently flooding itself.
Your temperature, elevation, fuel quality (RON?, ethanol blend, etc).
Mechanical history? Have you taken any comp readings? Done any leak down tests? You won't be able to jet around a mechanical issue.
Which leads us to squish clearance too. You can spend a lot of time jetting in circles if the head to piston clearance is excessive (as some stock setups have been).
And after all that, Capz gave you some advice back on page 1 "I used to run a 45pj and 180 main with one of the N3 series"
That's where I would start too. 45 N3EG#3 180 probably.. depending a whole lot on the answer to the multiple questions above.
KTM part number: 54731134000 ..available through whichever source you please, at probably a load of difference price points.
Main point to note is that it is the whole package working together. The whole carb needs to be in good order. The whole engine too. Be methodical and precise in how you approach it, and you'll end up gaining a wealth of knowledge and a bike that runs just the way you want it to.
Yes I am very greatful for the advice I have been given and I also thought I had given a lot of the info, I am new to the whole jetting thing and a bit bummed out I bought a bike that I can't get running correct, sorry if I come across as rude.
The carb is AS1Model of carb (AS1 or 2) - Suspect AS1 given its an 06 250.
By slide do you mean the needle? It is set to #3Slide number (and if it has a notch cut in it).
Not yet, I will do it before trying anything else though. I was asking about the JD kit as I was looking to collect a few jets/needles ready for when I spend a day trying to jet it correctly.Have you set the float height? The magic number depends on the model of carb. See above.
Temperature is around the 60-70F mark as it's approaching summer here in the UK. 0-1000ft, fuel quality is 95 I think.Your temperature, elevation, fuel quality (RON?, ethanol blend, etc).
I bought my first bike (kx 125) around 18 months ago and quickly realized I prefered trail riding/enduro type of riding, while owning the kx I did a top end and a bearing in the gearbox went so I split the cases and put fresh bearings in the bottom end myself.Mechanical history? Have you taken any comp readings? Done any leak down tests? You won't be able to jet around a mechanical issue.
This is all new to me and I have no idea what a squish clearance is, I guess more reading for me!Which leads us to squish clearance too. You can spend a lot of time jetting in circles if the head to piston clearance is excessive (as some stock setups have been).
Yesterday I went out and put the 180 main in and had the 42pilot in and the bottom end was fine as always but the top seemed even worse than the 172, I tried 178 but problem was still there. I rode for approx 30min, had a 10min break and when I got back on the bike it was 10x worse, I don't know what caused it but I ended up stopping for the day. Based on the videos I had been shown in the thread the past few days the bike was 100% running lean as when I would WOT it would make the similar noise to the KTM video, I stopped because I was afraid of heat seizing the engine.And after all that, Capz gave you some advice back on page 1 "I used to run a 45pj and 180 main with one of the N3 series"
I have just ordered the N3EG needle and a 45 pilot jet, I have just sent off my shock for a service so will probably be the weekend the next time I get some testing done.That's where I would start too. 45 N3EG#3 180 probably.. depending a whole lot on the answer to the multiple questions above.
