Intake Noise
farmerj
Is there any way to reduce intake noise from the airbox?
I have an '05 DE 300 (thanks firfighter,) just thought I'd see how quiet I can make it. I had a silencer from a KDX lying around. It fit well after removing a couple of mounting tabs.
Now the exhaust noise is minimal, and I was surprised at the lack of mechanical noise - at least compared to the KDX that rattles like it's about ready to come apart! (it is not.)
The loudest and most annoying noise now is from the airbox - when you accelerate hard, the low "BWAAAA" sound coming from that area is actually quite loud. I don't know if this is technically from the carburetor taking air in, or having the slide opened so that engine noise can come back out.
So I'm back to my original question - is there any way to reduce the intake noise?
Thanks,
Jeff
Thanks,
Jeff
*shrugs* Intake noise is cool. Lets you know your engines breathing deeply. As for hearing it I only every really here mine sucking at idle (more so with the seat off). Opening the throttle I'm too busy holding on and looking ahead to listen to the intake.
all kidding aside....I would just make sure that the air filter boot is secure to the carb bell and there is no leak, the clamps are tight and sealed properly.
I have sometimes wondered if some sort of noise dampening foam or suchlike could be applied to the inside of the airbox / base of the seat. Never tried it though
I'd say the same way to guy who asks if there is some way to make his Ferrari sound like toyota....
My answer is: WHY!!!!
Unless it really bothers you, I wouldn't bother. Have you ridden a Husaberg? The airbox is under the seat, I rode a new 390 a month ago... and was glad there was a seat there....
I had a Ducati Hypermotard with stacks/pod filters, LV exhaust. The intake howl at large throttle openings, combined with the exhaust would set off car alarms. A two stroke isn't even on the charts.
Hey Jeff, Hope you are enjoying the bike! I miss it already!
I agree with the noise. I can't figure out why some bikes are noisier than others. I had 2 KTM200's (both at the same time for a while), both with same exhaust and one was loud, the other was quiet.
I have run a DB snorkle on a KTM300 and it didn't seem to really quiet the bike just the exhaust.
Like mentioned before, I wonder if some foam inside the airbox itself would help dampen the noise. You know the airbox on a Gasgas just kinda sits out there and the sides are just the the side panels. On your KDX and other bikes it is acutally a box. Maybe sealing up the seams better with foam might help, but I would worry about the amount of air coming in and how that would affect jetting, etc.
I kinda get that. In the 4-wheel world, I can't get close to "Ferrari" - but I wouldn't like the exhaust note from the 5.0 Mustang's dual exhaust to sound like the old VW bug, that's for sure!
So I've pondered long and hard the question about why I would like it quieter. I think the answer is that then it wouldn't be so loud! :)
I appreciate the smileys on your post, GasTimppa. I suppose it is a bit picky to call intake noise "annoying," as I did. Some guys are removing baffles from their 4S exhausts so that they can sound like the Air Force jet flying over CenturyLink field after the National Anthem. Other guys are wrapping their exhaust pipes and buying silencers to quiet their bikes down for the neighbors. Most are somewhere in-between. We are a funny lot of humans, aren't we :) I suppose I've just gone a little over-the-edge in tinkering around. Thanks to everyone for your responses. And as soon as the rain lets up and I can get a good test run in (the joke is, "people in Oregon don't tan...they rust!), I can let you know whether lining the airbox with 1/2" foam makes any difference at all ;)
And then I'll probably go back to the TCII!!
Jeff
