JDs spreadsheet doesn't have the specs for the N1EF in its database. Which in turn doesn't help anyone.
/QUOTE]
Have just got the JD spreadsheet - great tool.
It does have the NEF1 needle in the database but it needs to be entered as
N - 1 - EF1 in the three columns....
/QUOTE]
That's the only problem with it, some entry errors aren't picked up. You can enter N1 E F and get a result. Then if you read it carefully you find it should be N 1 EF1
Doesn't half make jetting easier though.
In low range the torque is good and the engine feels OK but when I wan't to accelerate the engine needs a minute of silence and then he comes explosive.
Wide open is also OK.
But in the mide range this isn't a good feeling.
Now we solve this problem but this was no jetting problem !!!!
The dealer change the sealed crankshaft bearings (new since model 2007) to unsealed because the petrol in germany containes some alcohol.
This alcohol destroy the sealing of the bearings and the grease comes out.
If this is true its not good news for us either. How much ethanol in your fuel over there?
