Jim Cook
Bumping in this thread as i am still chasing down a rattle. It comes from the left hand side tough, low rps while the bike is moving.
What i want to find out if there should be play in the PV actuator arm and the PV actuator plate, here is a video i made a while ago
https://www.youtube.com/watch?v=QuJqHtTPUzU
Should i tighten the nut down to remove the play in the arm ?
Regarding a rattle in the pv assembly:
You can tighten the nut a bit, but as was stated, be careful because the stud is "fragile" and will pull loose from the bracket easily. I heat mine retaining nut before removal, and then replace it each time with new 5mm aircraft style locking nut. (mcmaster-kerr is your friend.)
Make sure that you don't need to take the slack out of your pv linkage by adjusting the bell crank governer that it is connected to. This is the cause of most pv rattling. This issue is covered in the forum quite thoroughly.
Also, make sure that you have the spacer behind your pv bracket installed. I saw some bikes come from the factory which were missing the spacer. If you look at this part diagram, you will see it as part #36 in the diagram. http://partsfinder.onlinemicrofiche...=27&c=0&d=2006 DE250 CYLINDER - CYLINDER HEAD
I hope this helps you.
Good Riding and Wrenching!
Jim
