bluespark
I was hoping someone could confirm that myPV is working proper?  It does stay closed at idle
https://youtu.be/pRd6anPzvuQ
https://youtu.be/lzYAjvG-mnw
No the power valve is opened by the engine revs, there is no mechanical link to the throttle so you will not see any movement if the engine is off
Special note: Don't try to move the plate around with the arm attached. It will dislodge a ball lower in setup and stop the system working.
No it applies to when the engine is off as well, but to be honest I believe you woul need to have an element of bad luck for the a ball to fall out. If the bike was on its side it would not have fallen out.Sorry to dig up an old post. I pulled apart my top end this weekend and noticed the shaft on my pv bracket is broken, so cane here looking to see if anyone has just welded it back on.
In any case found this thread (and this post). I'm sure I moved the plate around with the arm attached during disassembly. However, the engine was off. Is this warning only for when the engine is running?
IME, these engines make noise.
The powervalve flapper has a heap of tolerance in it, if it didn't it would bind up and need cleaning more frequently.
The clutch packs can make noise, the pistons can slap around a bit too. An alloy bash plate will redirect everything back up at you.
Add in a few vibrations, sloppy plastics, rad braces, a slightly misaligned pipe, and you get a symphony of sound.
Loosen the chain a bit and hear that slap too!
Don?t forget the clutch squeal. I have a rekluse clutch with a rekluse basket in my 2011 gasser. If I am a gear too high it will squeal like a pig. I have been riding it since 2011 and I have never ever had the slightest problem. I rode a 2018 gasser with a rekluse clutch, when I was a gear to high it would squeal exactly the same way as my 2011,otherwise in the correct gear the gassers never make a sound. My 94 CR 250 has a Rekluse clutch with the torque drive plate system and a Rekluse Basket, it never makes a sound even if I am two gears too high. Go figure.![]()
So,the best way to adjuts pv preload? Is there tips to do that?
