Well... I've put many hours on the Smart Carb now. I'd have to check to be certain but I did around 10hrs last week alone
..I still can't get the SC to work for me. Its very sensitive to adjustment and it seems that the slightest variance will cause inconsistancies between runs.
I've pulled the shock and revalved it, and gone back to the Keihin for some time. A pm has been sent to APT and I'm still willing to work with this carb down the track but for the moment, I want the set and forget that the Keihin offers me (ironic isn't it).
Last week I did around 300-400kms of riding with Lonetree and in comparison his 09 250R (with headmod by the same tuner) ran much stronger and cleaner than my 2010 250R. We both used similar amounts of fuel with him coming in slightly more economical, however mine was running rich off the bottom which would be to blame. I felt like I was making adjustments every time we stopped (and I'm sure he'd agree), where the AS1 with 40 N3EG#3 185 just kept on running they way it would be expected to. The same way my bike always did with the AS2 40 N3CW#3 178. Thats what swayed me back to old faithfull.
Michael has sent me a new nozzle to try, and Corey has sent some replacement D washers for the SC MR. The R080 I had modded is showing the rich->lean issues the stock needle showed, although after removing material is now running further towards the lean end of the adjustment. I don't think I'l touch it anymore, but also have the A100 stock needle here to use. I've aso ordered some set screw collars as a more permanent fix to the D washer which allowed some side to side rotation of the MR.
The slide spring on the SC eventually broke in well and didn't show any further signs of binding. The slide and all other components still look like new. The clicker assembly at the top was always hard to work with, however I haven't experienced issues as others have with it. I'm sure about the float levels if it has changed since originally setting it. I may do some bench testing while its out of the bike.
All in all, each and every ride since rebuilding my bike at 260hrs (now 315hrs so 55 hours ago), except the first break in ride using the Lectron, has been spent using the Smart Carb. The whole time I have been swapping, changing, modifying, and basically just trying to get it to work. Its time for a break!
APT has offered a few times to warrant their money back guarentee which is great customer service, however I'd still love to see this product work consistantly. I've had glimpses of what it can do and liked what I saw. Maybe Corey will exchange it for a cast model down the track, or maybe things will develop some more and he'll send out the revised parts.. I'm still hoping to have Dave at TSP do some Dyno work with the SC but don't want to send it to him with the Stock MR (which may have been faulty), and the R080 which I modified, as I dont think that would be fair to APT.
