Jakobi..I was running an 38mm AS2 178 main, 42 pilot and a n3cw needle, stock squish, about 70 hrs on the bike.. That was the jetting I had settled on after much messing about.. Bike ran strong, had a pretty big hit in the mid range and was okay on the bottom, but just ok.. Maybe on the lean side...The air screw really didn't do much and I was never happy with the idle.. Either to high or to low.. So far I'm very happy with the Lectron, there is more everywhere, the engine just runs way better. Still I will richen a bit as it seems a bit lean on the bottom.
I read of an idea to add a tee and a small valve to the PJ line for draining the carb, sounds like an interesting idea but I'm thinking that the diameter of that line needs to be constant as who knows what will happen if there are pressure/flow changes in that stream..
I've a couple ideas on how to solve the loose fitting throttle cable so I can keep the stock one..If it pans out I'll post my results..
Looking forward to hearing more about your APT testing....
