I did some street riding again (mostly to do some final Rekluse tuning with three heavier gold springs).
The only thing I did with the Lectron was to adjust the throttle cable slack.
I will have to do a plug chop one of these days to convince myself that it is running in where it needs to be. I like to jet my bikes a little rich. My current setting is probably just fine, but... gotta check.
The Gasser with the Lectron is a different animal. Taking it from the 38mm Keihin to the 36mm bore, alone, would make a difference. There is a lot of useable torque from bottom to mid that wasn't there before. It will suit my riding style. The stock 250's lack of bottom was the only reason I considered, but ultimately rejected, getting a 300. I don't think I'll have issues anymore, especially with a 12T counter-sprocket.
More on the Lectron -- the only notable glitch is that it likes to be cold-started with the throttle cracked. When warm, it'll light, but needs a bit of throttle to keep it going. I could fix this all with the idle screw, but that starts interplay with dragging the Rekluse at idle that I'm trying to minimize. If the Rekluse wasn't involved I'd be happy with the idle setting. I'll play more.
With the Lectron there is no longer that Keihin off-idle bog that persisted despite going down to a 38 Pjet. And the Lectron behaved well off-idle even when it wasn't completely warmed up. On the street I could go from idle to a raising the tire in wheelie mode with a blip of the throttle in about three feet. On the trail it would likely turn into wheel spin.
Perhaps I should credit the stiffer Rekluse springs?
I did several roll-ons from stopped to high-rev in different single gears and through the gears. As noted, the Keihin jetting wasn't near perfect, try as I might. And the AS2 had the feeling of different circuits coming on. Not hits, really, but it was a character change as the bike went through the speed range. My RB-modded AS1 was much, much better than this stock AS2.
Lectron Through the Rev Range -- Power comes on gradually from idle to WOT. There was no hit. There *might* have been one nano-second of noticeable change in the mid-throttle but I'm not sure. Maybe this is where the metering rod's effect minimized and the PowerJet started to show itself. The only reason I would be aware of this was the complete absence of peculiarities elsewhere.
I would say that the 36mm Lectron revs out just a titch more than the 38mm AS2. It felt like the AS2 should've had more in it, and fixable with jetting, or a needle. But it eluded me in the Keihin. The Lectron is not elusive in that regard.
So, I'm done futzing with the Lectron and done futzing with the Rekluse. About the only thing I have left to do is relocate the map switch.
Time to ride.
