I know that this is after the fact, but I wanted to add a point.
First.... I'm really glad that your repair worked for you. I would be interested to hear if it is still shifting hard, etc (the symptoms you spoke of which had no relation to the top end job you did).
Second. I suggest that you get a parts book and when you work on a component (such as the powervalve), make sure all parts are there and in the correct order. I've seen many new bikes come from the GasGas factory without the spacer on the right hand end of the shaft (behind the pv bracket where the linkage connects). My 2006 DE300 did.
I've seen many used bikes come through my shop for engine work which were also missing that spacer. Presumably lost during a previous repair.
This is usually apparent from the excessive rattling in the pv area as the engine is running.
I would often print out the specific page showing the parts for a job (from the pdf parts books and the repair manuals).
OMT: I have found the best clutch action (most quiet, with less drag and smoother shifting) by having a properly bled hydraulic clutch system, and by using Amsoil 0w40 4-stroke engine oil in my transmission. This is especially true when using a Rekluse auto clutch.
Good Riding!
Jim
The ISDT Reunion Ride is coming up in three of weeks. If anyone has a running dirt bike of '84 or older vintage, this is one of the most fun events a rider can enter. The ride is in northwest Arkansas at Mill Creek (Combs, AR).
http://www.ahrma.org/ahrma_pdfs/Z-20...bs_preview.htm
http://www.ahrma.org/ahrma_pdfs/Z-20...entry_2_17.pdf
