I'm about 200lbs (90KG) when fully geared up on the bike. I run around 110mm race sag, 35mm static sag, with a genuine Ohlins 5.4 rated spring on the rear at 12mm preload. I've gone with .46 rate up the front and 3mm preload. Both ends are TTX on a 2010 model.
Clickers are a bit of a variable depending on your year model and whatever valving it had (or if its been revalved). I think I'm running around 13 out on compression for the forks and maybe 11/12 out on rebound. I'm still tuning the oil level. I think I'll probably add some more and back off the compression. It should give me a plusher intial stroke with similar bottoming resistance. Rear I'm at 26/27 on the CSC, 17 comp, and rebound around 10.
