Wow 55 in about two weeks.... good effort
No, 60 in total since I'm doing these parts (est 2 years)
For jetting changes, I tried the new cover with the stock setup, N1EF-1, 40 175. Not much improvement. I went leaner everywhere, then richer everywhere to get a feel for what the changes would run like, mostly changing the pilot and experimenting with different needles.
I could never get rid of the softening of response with the cover. The bike seemed to make a bit, and I mean a tiny bit more power at the very bottom end. Anything above that it just seemed less crisp. The power was there, but the sharpness was lacking some from the stock cover.
The cover was well made and looked great but it wasn't working for me in my situation. Without the cover I finally settled on a 42, NOZH-1, 160 main. I know the 160 looks lean but with the rich final taper of the NOZx series and the 95+ degree weather it rocks.
I have the spacer fitted a while and like the extra torque and snap down low but I fell it takes a bit from the top end...
Odd that you felt that. I wonder if it could be in relation to something else?
When the PV is wide open the drums have rolled shut and the additional volume of the PV cases are no longer in effect. Its all just the exhaust port. Only when the drum valves are open (PV closed) should the extra volume be felt, and its effect is that of a longer/increased exhaust length.
Close but wrong if I can be an annoying winker. The effect is only to disrupt the returning wave to disrupt the positive effect turning up at the wrong time. So its not so much retuning as lessened effects of the pipe
