I'm not having "problems," I just want to tweak it to my liking.
The clutch has over 20 hours on it. It is well broken in. System bled to the best of my anal abilities. Same with the gap.
I got off the phone with Danny the Rekluse Tech. He said that my quickest and cheapest route to more clutch lever function would be to remove the X-rings that are installed to reduce clutch chatter. This was known to me but I'd rather not go there as yet.
He said that I would be safe to go as low as 1/16th inch (1.5mm) in clutch lever Free-play Gain which would result in a looser clutch pack.
I told him that I would like the clutch to engage a little slower off idle and would consider going one step stiffer than the blue springs. I wondered if that would cause the clutch to slip at high RPM. He said he could send me three gold springs which are usually for another application but would likely do what I want. He said that I should consider the springs to have the same range as a pilot jet in the carb. They'll slow initial engagement but will be overridden by the weigts at speed. Could be just want I want, especially since I like to have my motor idle at a higher RPM than Rekluse Inc. would suggest.
I am stall-phobic.
