When I got the bike it had an N1EF in it on clip 1. The needle the dealer gave me along with the CHN which I probably won't use says N3HG. I did a search too and could only find an N3EG at best. I can't find an N1HG either
The needle is silver and light weight like the N1EF, the N is capital, the 3 looks almost like a "B" kind of like they stamped it twice, maybe with a 1 then a 3 over the 1 as the 3 sits a little to the right of the 1. The H is clear and the G is clear, both capital letters.
I think the H is a long L1 and I know the G is 2.715mm diameter, one needle leaner than the F diameter. The crossover needle diameter on the Sudco PWK 3 letter single taper code chart would be an "L" at 2.715mm.
I have several needles coming to the house over the next week and I will test them all in my 300. I love to tinker!! I got my old KDX running very sweet after doing the same tinkering even with the RB mod.
If I find a needle in the stack that I like better, I wouldn't be opposed to sending you the needle to experiment with. Side by side, it is clearly different than the N1EF, in the fact that the 1st taper on the N3HG starts much further down, like the equivelant of 4 clip positions. The taper is also steeper. Where the second taper starts it is not a steep as the N1HG needle.
The bike runs better with the N3HG on the 3rd clip, starts hot or cold easily, lugs down well, and responds with the flick of the wrist. It does still four stroke a little, but it is not blubbery and as soon as you move you wrist off of the 1/8 throttle area it responds well. I'll put it this way, I am not a super fast guy. However I was able to pull 3rd and 4 th gear out of the corners from waaaay down low and on either map setting too, with NO clutch. Maybe this is normal or how it's supposed to run. I ordered the LTR cover to add even more bottom! Mwuaaahaaaaahaa!!
N3HG clip3
178 main
40 pilot
screw is a 7/8 out now
#7 stock slide
I did notice that the pilot screw vibrated out a tad during the ride, maybe 1/4 turn. I was going to put a dab of silicone on it to keep it in place.
