Jakobi
The idle issues for me have been fixed with a combination of different things.
Float height: I had to lower my floats about 2-3mm, just so gas doesn't drip out on the sidestand.
Needle diameter: the stock needle, 2.705mm in diameter passes too much fuel at idle. The 300 pulls a lot of vacuum due to large displacement and if you could measure intake manifold vacuum at idle it would be more than a 250 and more than a 200cc bike.
The #7 slide I have is notched at the center bottom and lines up with the needle jet block shroud creating even more vacuum in that pocket where the needle sticks out of the needle jet orfice (emulsion tube).
I believe that the pullover from the thin needle contributes to the rich idle condition. Think about it. When the motor is cold it may idle fine but after you ride for a few miles and it heats up, it idles really low or just stalls out.
So with the throttle closed, a thin needle, higher than necessary float height, the massive vacuum signal from the 300cc of displacement, and the notch in the slide along with a hot engine that doesn't need as much fuel at idle, yeah, I think the recipe is there for a hot no-idle situation.
I think folks may have sucess fine tuning the pilot jet, needle diameter and air screw. I didn't want to spend the money on a #8 slide as of yet.
The K and L diameter needles ran fine in my bike when the temps were in the 50-60 degree range. At 90 degrees, I needed a thicker needle so it would idle again.
I have to back Bailey 100%.. Same setup on my bike.. N1EF would not idle at all hot. I went to an N3EG which had to pull over a bit. Today I dropped in a N3CH and once again the idle circuit cleans up even more.. This is all with a 38 Pilot. I think if I went to the J I may need to step back to a 40 pilot..
Good work mate, couldnt have explained it any better myself
