I'm the original OP.
After a ton of tweaking, here's the dilemma.
My current workable setting:
15C - 750' ASL
2010 EC300 with Airstriker I
38 Pilot
JD Blue needle - 3rd clip
AS 2 turns
Idle screw 4 turns from full in (~15 turns availble)
7 slide
178 main
Here's the deal. Like so many others I'm fighting an idle screw that has to be turned way in. With the above set-up I can get the bike to run well. Steady idle, barks off the bottom (a little too much for the tight woods stuff), the main is probably a little fat but I haven't had the chance to run much WFO stuff - it's been a soggy Spring here.
I don't get why the idle screw has to be so far in? This has been the case since I got the bike. With my current set-up I don't think it's a case of 'ticking/pulling over' - the idle screw pushing onto the slide.
I know some say I need a leaner needle. I've tried the leanest needles I can get my hands on (JD Red) and still the idle is way turned in. I'm waiting on a NE3H needle. When I compare a N0ZH needle that I have, the JD needles (blue and red) are larger in diameter through the body and at the tip. I don't think a leaner needle - if I could find one -is gonna solve the problem.
The 38 pilot has got the idle screw out more than any other set-up. I tried fatter pilots (40 - 42 -45) and the idle problem got worse and they were way too rich. With a 42 the bike would start cold without choke, and loaded up after a short time at idle. The 45 was worse. The 40 seemed ok, but the 38 gets the idle screw out more.
I'm a little confused? The bike seems good with the present set-up, but I don't know why the idle screw has to be so far turned in? I don't have any security torx screw bits to check the pilot block for missing o-rings - see this -
http://www.gasgasrider.org/forum/showthread.php?t=5311&highlight=idle
A friend gave me a B5EF needle. It's 2-3 mm longer than every needle I've tried yet - that's gotta be way leaner. I'm gonna give it a go just for shits and giggles. Otherwise I guess I'm gonna just accept that this beast has a way turned in idle.
Anybody have any ideas?
Thanks,
Jason.
