I stil don't have a nice photo of her posing fully dressed.. I'll work on it.
The footpegs seem to sit a bit strange on her too. I think its the actual pegs themselves and that the stops are touching a bit soon. I'll likely just deal with it for a bit and then replace them with something else.
My only gasser that I purchased new was an 07 250 that came from the factory with one footpeg angled backward and the other angled forward both at a 10-15 degree angle. Maybe the frame got bumped in the jig before the peg mounts were welded on. I never fixed it just rode it that way.
That bloody '10 is photo bombing again hahaha.
Haha not a chance Stu!
Was it you that had issues with the rear brakes?? I can't even really get the back end to lock up while standing on the pedal. Front is behaving like Simmo said. Very progressive.. reminds me of a Yamaha. I think I prefer a firmer bite so I'm not sure what I'll do to address that.
Suspension seems to have broken in considerably after less than an hour. I'm sure it'll loosen up some more yet, but looking promising. Can't wait to get it into some real nasty crud and work out what needs to be done to make it even better.
Force rad guards bolted up this morning.
P3 Composites Guard under the Christmas tree (and maybe a G2 Quick pull throttle cam too).
Still need to mount up the brush guards, bash plate, and the kill switch.
I'll grab a handful of M5x25 bolts when I'm next in town and will add the 8mm PV spacer on and see what that does to the bottom end grunt.
So far I'm at 40 N3CW#3 178 and its running pretty well. Doesn't feel quite as vibey/rough as the old donk. Power wise I don't think there is much in it. The old one is running 2 rear teeth shorter gearing. I think the new one feels a bit softer/burblier off the bottom but takes revs a bit easier. Reminds me of how my old engine felt before I did the head. I'll likely do the same and have this one machined up ASAP. Just not sure if I want to try and get an S3 working, or just mill down the stocker. Anyway, not sure when I'll have time to drain the coolant to measure that up. I'd like to check the PV tension as well but seeing as last days were spent rebuilding the old girl I think I deserve a bit of time off before hooking back into the next one.
I have the galfer wave rotors on both my 2010 and 2013. The rear brake feels like its just not biting at the disc. Possibly still burning the assembly grease/oil off the disk. I have given them a clean. The front is more to do with actual feel at the lever. The brakes still work quite well, but the lever has a soft progressive feel rather than a very firm bite.
