StuJohnson
For those of you having some clearence issues with these 23 ounce flywheel weights,if it was me Id fire that baby up and use a quality file that can be cleaned and turn that flywheel and nut down,starting with the nut,and then knocking that sharp edge down,and finishing with a face cut if you had too.The bike is your lathe.
This is exactly what I did !!!!
But I really want to use my Ransom Machine Works AL cover. But I need to have about 1mm machined out of the inside in order to clear the old S3 weight. Just need to find me a local machine shop.
