twowheels
So we've come full circle.
My questions now are:
-Can re-valved and re-sprung Sachs forks be as good as re-valved and re-sprung Japanese or WP units?
-If not, what are the choices for the very best forks out there?
-If not, what then is the simplest way to achieve front fork nirvana?
-Is there a true bolt on solution?
I've searched and searched and read and read and I just end up with my head hurting....
I've had reasonable success tuning the Sachs OC forks, and I believe they end up working about as well as OC forks can (relative to KYB and WP for instance). Ride that and then spring for the TTX inserts later if you like that sort of thing.
Simmo737 went that route, with a re-valve first and then the Ohlins magic - I think SwaziMatt is still on the revalved Sachs that I set up for him.
