LT racing jet kit report...
All the needles you have listed are the same needle with only a differant straight diameter. None of them will work. The needles you listed have a rich spot at off idle that makes the bike stumble and a rich end taper that makes the bike run flat from mid to top.
The N3EG needle is an optional needle for an 03 Yamaha YZ250 two stroke. The needle for a 99 Honda CR250 part# 1369D it is identical to the CCK except it is 1/2 clip leaner. CCK#3 = 1369D#3.5 These may be easier for you to get than ordering needles from the USA. Dave
Thank you very much Dave I'm gonna order these needles from my local dealer and return here with results after I tested them.
Toni
Here is what I am running in my 04 DE300 at 900 ft. elevation.
42p
N3EH 3rd clip
178m
I would say its performance pretty much mirrors what Dave says about the N3EG. My tail pipe isn't perfectly clean but the bike pulls as strong and clean as anything I have tried so far. I would try a 175m but I don't want it to pull any harder on top!
I'm thinking about trying that 1369D to help find the finish line next year when I ride long course.
Toni
Now I've tested the following jetting. 42 N3CG#4 178. And I'm very happy about the results. Now I can give full throttle on a high gear from low RPM's the motor gives plenty power through the hole RPM scale without any hesitation.
My bike has never felt this good.
Thanks again Dave:)
took it out after dropping the needle 1 position. temp around 80. with the a/s 3 turns out it was very close, but I'd still liketo drop the p/j to a 42 and run the a/s about 1 1/2 out which give me latiude for adj either way. I must say over all this jetting set up is very good. thanks Les Tinius!
jetting when I'm finished should be as follows:
mj=178
pj=42
jneedle=2nd position from top
a/s= ~1 1/2
#7 slide
:) :p :D
Just for my own info,what needle are you using?
Pobit,
I ran your jetting suggestion; CCK needle on middle for the first time yesterday and it was sweet. To be precise I ran 42 pilot, CCK on middle, 180 main and #7 slide. Pull was very smooth and linear which is what I wanted. Still not sure if I want to keep the bike as while it is now much better it's still too strong for me. It's great fun for a while but a lot of my events are tight, wet woods and run for 5 - 7 hours. A 250 thumper would probably yield a better result being nice and mellow.
Hey Steve,
The needle I'm using is from Les Tinius at LT racing. I am using his jet kit.
It must be noted that now I am using a #8 slide also.
You are mirroring the jetting I used on my '05 EC300. Now, if you get your head worked over, your going to pick up a ton of low-end. I tammed mine back to reasonable output with the CCK needle, going back to the #7 slide and dropping a tooth on the rear sprocket. If I go out to the desert, I'm swapping to the #8 slide and possibly the LTR needle. Its a beast jetted that way with Ron's headwork, but I like it when things are more open.
Mike Baxter
Rode the bike with Pobit's jetting in an event yesterday and it was the best it's ever been but I still want a 250 thumper. There was one bit of the course where I was glad of the power (2 foot deep mud) but most of it cut up badly in the trees, was slippery and tight and a 300 2 stroke just isn't the tool. I might keep it though for when I do more open fast courses. Yesterday's event was over 90% in trees so close you often had to stop and squeeze the bars through. I'd like to try a GG 200 in an event but that's difficult to arrange. I like 2 stroke simplicity but I really struggled with the 300 towards the end of the competition - just couldn't open the throttle slow enough for my tired arms and shoulders even with a G2.
Thats why the EC250 is so good. Most of our events on the east coast USA are like that, especially southern NJ.
Try backing off your timing 1mm and adding a base gasket to drop compression a little. Does the bike have the OEM reed spacer or was it removed?
New EC250 2008 jetting
I have just bought a new 2008 ec250. Its a fantastic bike! I have owned 3 250 exc KTMs and a YZ 250 but the suspension and handling of these GG's is just incredible.
My only complaint is the recommended factory jetting is off, being a little rich of the bottom to mid but has a strong linear pull from mid to top.
My current settings are:
PJ 40
Needle NIEF #3
MJ 180
Temp 50 to 70 F
I lowered the needle to #2 and she runs a bit crisper but still not ideal. The local agent recommends the following settings which he says works on many bikes here in Greece:
PJ 42
N1EG #3
MJ 178
I feel these settings will be really too lean. I called the Keihen agent for a CCK needle but the don't have it in stock and will not import them. Should I go to the equivalent Honda needle if available. Any suggestions?
Of the three bikes listed, the 300 has the most easy to use bottom end. 200's squirt through the woods easier but they require more throttle skill than a 300 does. 250 four strokes do work well for tight and slippery conditions but they leave you wanting for more power any time the trail opens up.
If you have a DE model with the small ignition, you may want to try adding some flywheel weight to smooth out the power. Here in Minnesota where I live, it is always wet and sloppy in the spring and I run a small weight on my 300 to make slogging through slippery roots and rocks easier for long enduros. Dave
PJ 40
Needle NIEF #3
MJ 180
Temp 50 to 70 F
PJ 42
N1EG #3
MJ 178
Your not too lean. Your agents recommended setting is not much differant than your original setting. The leaner G needle diameter is offset by the richer 42 pilot. I doubt you would notice any differance in performance.
Jetting is a personal choice so you have to try a few differant settings to see what works best for you. Skill level, riding style and your riding area will dictate which jetting is correct for you. For an 08 250EC used off road for trail riding, I would try a 42 pilot CCK#3 178 main, #7 slide and compare it with a 42-45 pilot DDK#3 175 main #7 slide for sea level, 65 degrees. The CCK will be smooth on the bottom with a good upper pull. The DDK will have a harder off idle pull with a torqy mid to top pull. The DDK needle will require more throttle control at small openings and likes to be rode under a load at wider throttle openings so it is for more skilled or open riding areas. Dave
Thanks for the reply Pobit. Today I tried the following:
178 main
42 pilot
n1eg #3
The bike would stumble just before the power valve was starting to open so I lowered the needle to #2 and the stumble nearly disappeared. Weather was cold (about 45) and damp and engine was revving up too quickly.
I'll try to see if I can get the DDK or HONDA needle. On what bike was the CCK a standard nozzle?
I've been on the Keihin site and cannot find the correct "reference" to the N3EG needle, they all list 3 letters as the reference after the N427-48 part number start. What would be the straight equivalent, or the closest to it on the Keihin site's number/letter scheme?
The equivalent OEM needle diameter number for G is 66
It is the second pair of numbers, the first pair is the Taper and the last letter is the L1 length. These are for straight single taper needles, For multi-taper needles I can not find the equivalent on the Keihin site either. Maybe Pobit can help on this one since he has a lot of knowledge on jetting.
N3EG or any N series is not a standard Keihin needle, is a triple taper OEM needle for Yamaha. All you will find on the Keihin site is the standard single taper needles. The JD jetting XL spreadsheet is handy for comparing various needles, except his own of course!
R 1369d Needle
Hi again Pobit.
I have been trying to set me 2008 ec250 but just can't get it right.
I have tried the HONDA needle at 3.5 clip position 42pj and 178 mj air temp around 20 to 25C and the bike would really sputter all over the midrange so I changed the needle to the original N1EG #3 42 pj and went to a 175 mj. The 1/4 to full open throttle reposnse was goog but was rich right off idle to 1/8.
It seems that this bike works better with the needle at #2. Should I try dropping the needle one clip?
Can I put the 1369D at #2 or#3 and drop the main?
I race in enduros and scrambles and I need power across the board but more in the low mid rev range. I like the motor to screem on top and lug on the bottom.
Thanksj
Glenn I have an 07 250 with the heavier EC ignition that runs very clean except just off the bottom from idle to 1,000 rpm. If you run it that slow on a hill it will load up and require a down shift or clutch slip to clean out. Any suggestions?
Ken
178 main
42 pilot
#7 slide
stock needle clip : #3 position(temp. 40-50 degrees)
next position leaner (51-75 degrees)
top (76 degrees and above)
It seems I'm in the same situation as you with the exact symptoms. I went down on the main to 175 but lost a little on the top. Maybe if you go to a 40 pilot the off idle rich spot will go away. What needle are you using?
