You might have some fun with that. Won't be too many shims available in the size you're working with.
Believe stock was
Rebound (from piston)
12x.10 - bleed
20x.10 (2)
18x.10
14x.10
11x 2.5 - collar
A start is to remove the bleed shim, and it makes a decent crossover if you're that way inclined. You'll then want to significantly beef up the HSR portion of the stack.
EDIT: Yes, My stack was like you describe.
I have now rebuilt my forks, and for some reason, the rebound seems to be faster (less damping) than before. Perhaps lower friction from the SKF seals? or just me that can't tell if it's different? I don't know.
In any case, I have concluded that I need to to something. I would like perhaps 10 clicks more damping from what I have, to be able to place my clickers somewhere near the middle of the scale.
Edit: I have some 20mm x 0.12 shims, so I have something to install in addition to the OEM shims. The question is whether to use one single 0.12 or one 0.12 + 0.10?
According to the math, a 0.12 shim is approx 1.7 times a 0.10 in stiffness.
On the positive side, my compression damping now handles trail trash a little better, while I still would like some HSC less (I think).
I built a stack like this:
28 x 0,10 ( got this idea from the Beta stack)
12 x 0,10
2 x 32 x 0,10 ( replaces the 2 x 32 x 0,15)
21 x 0.10 ( here comes Jacobi's suggested crossover)
3 x 32 x 0,10 ( replaces the 2 x 32 x 0,15)
26 x 0,15
24 x 0,10
22 x 0,10
20 x 0,10
18 x 0,15
2 x 11 x 0,20
I think my next iteration will be to either remove one 32 mm shim from the HSC side, or try replacing the 26 x 0,15 with a 28 x 0,10 (as I have these in stock).
In reducing the compression bleed as described, I would have expected that the rebound would also give slightly more damping. That didn't happen as far as I can tell.
While building and testing stacks, it would have been nice to use some simulation software like the Restackor program or similar. Did any of you measure up the pistons in the Marzocchi and if so, are you willing to share the measurements as used in the Restackor?
