desertgasser300
Banned
I only meant it would be overkill because I'll have a total of 6 bolts holding it on if I drill the lower triple, which is more than any other piece of plastic on the entire bike.
As for the airboot hitting the shock, I'm afraid I'm going to have to unbolt it and rotate it significantly away from the shock. It lines up with the carb very nicely where it's at so I'm considering just melting it.
Ok, screw everything I said about that filter retention device. It's really simple. If your plastic wireframe that goes inside the airfilter has prongs sticking out of it, cut them off if they don't have corresponding holes in the airbox. I just reused the one I already had. I don't like the new one that came in the kit. Here's a picture of the device in action. Sorry for the dirt, I do all my work outside![]()
The metal piece around the airbox isnt needed on the later models. The prongs on the filter cage are there to fit inside the opening to square up the filter on it. The older bike filters screwed in place, that is why they had the metal rim. They really need to put directions with these kits. I hope you didn't mess the filter boot up by riveting that piece back on?
Don't melt the airbox boot. Don't chance melting a hole in the boot, then you're in for a whole new set of problems. Heat it up with a heat gun or blow dryer.
