Newer Plastic on Older GasGas show your bike
Here's another pic of the tail being installed.
And my 300 that is its garage mate, ha.
Just waiting on the Carreras transformation kit and other bling! :D
ridepg custom graphics.
2010 shrouds
06 and below 200cc rear fender
2010 Honda CRF front fender
CR fork guards
This is my 2005/06? EC/DE? 200 converted to a 2011
powder coated frame, rims, swing arm, 2011 subframe
I used 3M non slip tape on the frame so the paint doesn't wear off
The number plate graphics are from BikeGraphix they make a great product
the bike didn't come with a headlight so I put a piece of rubber over the hole, however I am looking for a headlight housing from a 2011 if anyone has an extra laying around
Received a huge box of bits from Spain! Started fitting it, I think I have the airbox sorted but trying to get everything lined up is proving time consuming!
I stripped out the old filter and dismantled it. I used the original rubber boot and the inner metal part that the filter screws to. Then attached them to the airbox front wall. It took a little trimming but it all appears to fit ok!
Thats what I did just had to take time to get holes lined up perfect
what did you have to trim? I didnt trim anything just left the boot in the sun for an hour or so and it went in not to bad once I worked out how it works
Unfortunately we haven't got any sun! Trial fitting the rear end today and started to fit the graphics! It's close but not close enough :confused:
Starting to find out what all the bits are, still confused about seat fitting and a couple of the little bits!!!!!!
I thought they came with graphics already on :mad: Not my strongest point!!!
Question Red or White fork protectors? I have both but only one set of graphics.
A couple more pics plus a quiz!
Name the items on the plastic bag and tell me how they fit and you will win eternal stardom!
The two rubber grommets hold the headlight pins snug onto the fender
red metal Tube and large spring hold the new style air filter in place
the white triangle plastic item mounts behind the headlight mask to hold the brake line in place
the small spring and the black clip are part of the headlight adjuster assembly, should be a white plastic square to go with it, my kit needed a proper size nut and bolt to attach, it wasnt included
The shouldered washer and bolt setup maybe for the top gas tank mount? My kit didnt come with that.
The black push pin is for the airbox...I used rivets on mine
I don't think I will need that then!
Gotcha!!!!!!
I have bodged up my own system at the the moment~
I have rivetted all of mine together as well!
Thanks for that it takes a lot of the puzzle out of it!
ok ill put up a couple pics,but I have one grommet holding the headlight snug on mine through the fender
your tank is held in with a top bolt,im sure you had one in there originally,looks like that's what that 8mm bolt with that washer that fits inside the tank hole
