I suspect one of two things, in this order, probably both:
Rad cap
over filled radiators
Bad rad cap will allow the bike to over heat, not just vent. Pressure maintenance allows the bike to operate at a higher stable temperature, a bad rad cap will vent, causing temperature spikes.
Over filled radiators won't allow any room for expansion of the fluid and therefore the rad cap has to vent off. A bad rad cap in combination with over filled radiators will cause over heating, or at least symptoms of over heating (biol over, pinging).
So, get a new cap, like a 1.6-1.8 Bar, and just barely cover the fins in the radiator with water/fluid.
Simple fixes first, then dismiss them with evidence.
