twowheels
...check out the pic and let me know what you think. It looks fine to me. But then what is that sound? Can the parts of the actual PV wear out? Guess i'll know more when i tear it down. Fork and shock already out to be rebuilt. And as far as low end power loss can't notice much there apart from likely needs rings anyway.
The zero-rpm position of the actuator plate looks fine to me.
Beware the knock that increases but that you can't find the source of. I had a KTM 200 do that once - it had never run stronger, then the knock ceased ... when the crank pin bearing let go
When you've got the top end off take the time to check rod play, and it likely wouldn't hurt to remove the ignition cover and see if you can move the stator up and down excessively.
