desertgasser300
Banned
Wonder if I could stretch them to my 10/11 plastic? Looking good! Thanks!
I bet the guys at PG graphics could make a set up to fit the 10/11? They are very cool guys to work with.
Here's a few updates on mine since I got the top end back together. I have been in love with the Tubliss on the rear so I did one on the front. Also I did a pull type switch on the head light assembly like the KTM's. I kept hitting the bar mounted switch and turning the headlight on and off.
Serviced the linkage and swingarm bearings, figured since the shock was out getting re-sprung and I never looked at them when I bought the bike I'd have a look. After 25 hrs I wasted my time looking, all the bearings were full of clean grease. What's more
Annoying is not only did they not need doing, two of the bearings spat the needle rollers out and I had to re-pack them, the locating nibs on most of the rollers has broken off. Clearly good quality needle rollers aren't used by the factory on assembly so ill plan on replacing them in the near future when I could be bothered.
Anyone have a bearing code for the '14
Linkage by any chance?
The bearing specs for the GasGas EC and FSE swingarm pivot and linkage has not changed since the original design in 1996. It is still the BE25614010.
In the past, before I got All Balls to produce their linkage and swingarm kits in 2002, I often used the rear linkage bearings from Kawasaki, for their '99 KX250. The rollers in those are "caged", as opposed to the "not caged" (which have more rollers but less room for grease). They worked well, and I liked the estra grease.
Good Riding!
Jim
Did you put the switch on the ground wire? To keep from running down my battery during trail working days, I simply disconnected mine, and would lots rather install a switch such as yours.
TIA,
Jim
Started it & rode it for the first time since the start of the rebuild in June, stripped to the bare frame and back together again.....started 2nd kick..![]()
Nice job Fred. Enjoy.
Great looking bike Phil, and great finish. Wait a min. I didn't know that beer made it passed the mississippi river. lol
