stainlesscycle
Bad reeds alone will do what you describe (sloppy low end), and I know for a fact and from experience that some of the fiberglass Boyesen reeds on the RAD valve get affected by modern pump fuel. If its an '03 I'd consider the reeds junk unless you replaced them yourself.
i would think it would be incredibly difficult to start and even ride with bad reeds... i had a reed crack on my 200 and it was tough to even keep it running enough to limp home.
i replace reeds every couple of years whether they are good or not. they will fail eventually, and it's something you cannot repair on the trail.
the good thing about your whole dilemma is you will know more about your bike then you did when you started
once you get it all sorted out you won't need to play with it anymore (unless you're like me and constantly tinkering/searching for the 'perfect' state of tune...)
