the reason i switched to 36 carb was to get a more consistent idle, and felt the 38mm carb was just plain old too big for the 200... i assumed a smaller carb could get increased fuel velocity, and gain performance......... ltr was the first to suggest the smaller carb.
no adapters of any kind. fits right in there.
how are your 200's jetted? i could never get the bike to not stall when hot with 38mm carb, unless i jacked the idle way up, and pretty much out of the idle circuit. changing pilots around got me to idle, but lost performance. it would idle fine till it got hot then slowly die. i'd have the idle screw all the way in, and start turning the throttle adjuster so much that the slide wouldn't slap shut...i'd start a race fine, then 10 minutes into it half to jack the idle way up.
