AND ANOTHER ONE
I so did not want to look, but this thread has been fricking bothering me.
Look what I found....
Now here is the interesting thing. Not only was it rubbing like the other photos, mine is also rubbing on the side. BUT only on 2 of the impellers...... This makes me believe the cover was not fab'd with any tolerances or not checked.
If you look at this photo below. I believe that the shiny part of the cover that was ground down was done at the factory. Whereas the dark groove marks were made by the impeller....
If you find a similar problem with your impeller...My offer to take that piece of crap off your hands still stands. I won't even charge ya, to take itGreat now I know Im going to go home and pull the cover and find more annoyances with this bike. Stay tuned for pics.
I'm curious. With the common woes the 2012 owners have had to address...Are the owners of 2013 models investigating known issues concerning the 2012s? Have those known issues been largely addressed, by the factory?
Just got done talking with our pump shop mechanic at our mill. I work at a paper mill. Let me first say that motorcycle and stock pumps are very similar..though I do realize this is two different worlds. The mechanic said that their impellers rub all the time and they even have to "Take up" on the pump to increase the pressure. Meaning they decrease the distance until it rubs. Makes me wonder if gasgas didn't just use the plastic ones to get in the ballpark and then allowed in their manufacturing that some would rub.
Why is my impellor brown and everyone elses white??
One can only hope that things will change in this respect. They really have the art/scence of building an excellent performing bike down.
For you guys that need a quick fix, either the Checkpoint impeller or the kit from Motocrosscenter. Kit is easy. If just using the Checkpoint impeller, you can stack gaskets to acheive adequate clearance if machining the rear of the impeller is a problem. Also you could get an older cover from a part out. They had a fully machined inner surface, never had any interferance problems with the old bikes. The Checkpoint part has been around awhile, its actually a copy of the LTR impeller, which Les designed around the older bikes. Just do something because those pics are not looking good.![]()
