nambo-trev
Since its easy to see where the impeller rubs, one would think it should be easy enough to file the impeller down to add a little clearance.
Have you checked yours yet bro?
Stu, mine looked just like that. It wasn't rubbing on the sides though.
I bet your glad you checked it.
That's assuming that the water pump impeller rubbing is the actual cause of failure.
I've got my '11 250 apart now. I was getting some oil residue on the radiator cap. My impeller isn't rubbing but I've got a lot of miles on the bike so I'm gonna replace the bearing. When I replace the water pump seal with a new one, do I need to apply grease, oil, or put it in dry? I'm not familiar with this type of seal.
