ssaulnier
The advantage of removing the entire ignition cover is that you can then remove the bendix, poke it into the bore on the Bendix cover and fiddle it about with your fingers in an attempt to identify too little clearance. That is the idea anyway. But I wasn?t actually able to determine anything except that I thought it felt ok but was actually too bound up.
But perhaps my technique is flawed....
But you also get a chance to have a good look at all the bits inside the case.
