Brian,
Kind of confused here.......If Gas Gas did development at the Corduroy or anywhere else in North America, what would change about the bike? Maybe a larger tank? Heavier springs for larger riders? What else?
Clay
If any given mfr developed offroad bikes for the purposes they are actually used for by the 90%, I think they'd have a bit more built in versatility, armour(or have certain parts designed such that they don't need it), 1 piece easy access airboxes- so the bike could traverse water up to the seat(or almost), longer 5th and 6th(or 7th?), for Desert, road connection & fire road use (not trail use, as Neil mentioned).
Durable & robust shifters & Brake pedals.
Have consistent & common fastener sizes for ease of trailside maintenance & repair.
Why not have real barkbuster style handguards instead of those cheesy plastic roost deflectors? When was the last time you saw a woods, or trail rider without real guards?
Robust, adjustable built in steering dampers.....
Seat heights are a debated issue, but it's a lot easier & cheaper to make a bike taller with a tall seat, than it is to make a tall bike shorter. Better to go a bit shorter from the start, rather than Husky tall. When the rest of the world catches up to the Dutch and Watutsis in average height, that could change..........
With all the clutches Rekluse sells, I'm kinda surprised a bike mfr hasn't started offering them by now.
GG has a reasonable sized tank, but having a bigger optional one would probably not be a bad idea for the desert, big country and OZ guys.
Springs have to be custom sized for many guys, so probably not much can be done about that, unless the new air forks(on Kawi I think) prove to be reliable long term- that could solve spring weight issues..
Methinks Scotty has exaggerated a little bit
However, the fact is that most guys anywhere end up adding at least 10-15 pounds of stuff to their bikes, much of it armourplating. Why? cause most of the areas where there are trails are rocky-anywhere in the world. There's a giant aftermarket that creates products due to how the mfrs design(or don't design) their bikes. Al Randt has done Ok in this regard...just for example.
Scott may say he doesn't want a 'cord designed bike', but if he was actually buying a bike to keep & use extensively for 3-5 years(like the 90%), he may change his mind.....
This post and my previous one isn't meant to criticize the current GG bikes, (I think they're pretty good, else I wouldn't have bought one)
but is just my personal thoughts & observations(in answer to Clay's question) on who buys offroad bikes and how they're actually used.
I'm sure I've left out a few things also.....
B.
