I decided to service my 48mm Zokes, they already have 35 hours on it so I figured good time as any to make sure all is in its right place.
Took everything apart except the inner cartridge, still figuring how to do it properly without breaking anything.
I found that the oil level in the outer chamber was around 230cc, with all the lost cc in my hands and pants
I would say 250cc ... From the values we have been reading here , they do come up short.
In the cartridge oil was just about the same ~250cc . not sure if that's correct or not but I do know it's going to be a pain to close the cartridge due to the inner pressure, I now understand the gizmo Leo had to built with straps to make this work.
The oil I removed from the outer tubes was pretty contaminated even though the bushings don't appear to be worn, in any case I will replace them.
Funny was to find the oil inside the cartridge had quite a few foam on top, just like a beer
, don't know if that's a good sign of the oil quality.
Apparently the oil seals from a 48mm KYB should fit this forks as well in the Sachs 48 but the reference of the NOC seal I removed is 48x58x9 and the KYB is 48x58x8,5... Do you guys think this will be an issue ? There will be a 0,5mm gap between the seal and the upper ring (the one between the seal and the bushing)
I'll post some pictures later on
