Vindicator
If you overfill the carrtridge, will the excess oil be pushed out the bleed holes when inserting the comp / PFP assembly? This is confusing as Leo has said it does, and Evan Yarnell has said it does not. It makes sense that it should. Could there be differences in the forks?
I did not overfill but I can imagine it would be pushed out the bleed holes until the PFP o-rings seal the space below those holes. My understanding is that these o-rings seal the PFP and are responsible for maintaining the inner pressure, no oil should pass by these o-rings with the consequence of losing your desired PFP pre-load. I'm not sure but I think that if you overfill the cartridge you will be pushing the PFP up more than the 7mm standard pre-load Evan mentioned .
I can tell you that the more oil you add the more painful is to close the cap
I would think that the reason one extends slower is due to less pressure, which is due to less PFP preload, lower piston position from a leak. What size orings?
Yes, I hope that's the reason . I don't know yet, I have to tear the cartg apart again
