Marzocchi 48mm CC Forks
On another note, the holes in my cartridges were fairly sharp on the inside, enough to tear lint from a shop towel. Vindicator, maybe this is the cause of your oring leaks, nicked orings as the lower edge of the holes is right on the edge of the PFP bore. A small piece of #400 on my finger cleaned it up nice.
Thanks, I'll do the same to mine the next time I service it
The question of why some of these cartridges stroke to different lengths still remains. I can't see how all the air would be purged without a slight overfill, and if the taper in the PFP rod allows a blow off of air and excess oil to the top of the piston and ultimately the outer chamber, why should there be a difference between forks? Also why such a longer compression of the spring on assembly. Is it working against the top out spring to an extent?
I also find this quite intriguing, I'm not sure but I think the air should come out by the PFP shaft recess the first couple of times you stroke the rod. At this point the fork should not be using the full length of travel because there's more preload than it should and the piston is toping out against the cap. Only after the air/excess oil is expelled the fork would have the full travel again. This does not mean you can't have more than 7mm of preload, the limit should be the recess/full travel . After putting together one of mine I had this scenario on 4/5 strokes of the rod. I could see the the piston up and down through the holes reaching as much as the bushing. When compressed, small amounts of oil escaped between the o-rings and would come out through the holes. When flipping the cartg upside down small quantities of oil would come out, possibly escaped from the recess. In the end there was a noticeable decrease in the force needed to push the rod and when fully compressed I could now see the upper o-ring of the PFP only .
I had seen the recess but I did not quite understood its need until Leo mentioned how he bleeded his cart because both of my carts are bleeding oil by the orings. Again, I'm not sure of this but I think no oil should be allowed to pass through the PFP o-rings because this will affect the desired preload . Bad PFP o-rings is the only explanation I can think off to having some forks with different preloads, assuming they were serviced with the same amount of oil . Any ideas ?
Next time I will also dismantle the PFP to take some metrics and do some math related to the max preload it takes.
Well, I hope do do mine tonight if I can get to the shop for oil. What I don't understand yet is how it is possible for the PFP piston to top out and stop the damper rod travel before the excess oil and any air is vented by the tapered shaft recess/center PFP seal? It cant be hitting the comp piston. I'll measure the comp assembly more before putting it together. Maybe I just didn't force it hard enough. A caliper will tell the story.
Yes the lower outer oring should seal, period. The only oil in that area should come from the center seal/recess, or maybe some outer chamber oil that is splashed in during use.
Note that the 5mm holes in the cartridge are NOT in the PFP piston bore (just above it, on the edge), and will vent any pressure over the lower PFP oring. The upper oring will constantly engage/disengage the PFP bore, so if there is a burr I can see it damaging the upper ring, and lower ring on assembly.
I suspect that the small holes in the bushing land might allow oil to reach the bushing.
You guys are making my head spin!
Why don't those Italians put out a manual?!:mad:
Me too perhapas when one of these guys have finished pulling down then putting back together they will take a few minutes and write a step by step for us that are currently laying on the ground with a head spin:o
When servicing the forks, I ordered both KYB and Yamaha bushings to compare
Bushings from left to right, OEM Marzocchi - Yamaha - Kayaba
The Yamaha and KYB are exactly the same as far as coating and metal, if mixed in the same bag one could not tell it apart. The OEM is different but it seems to also have excellent coating.
Completed the setup with these
Here's the oil seal compared with the stock NOK
I ordered both the SKF reference for ZF Sachs (48x58x9) and the KYB (48x58x8,5) to compare, they fit like a glove. As you can see it's quite different from the oem, I ordered as being the low stiction model, let's see how long it will last.
No surprise that the Yamaha and KYB are the same. What's not exactly the same are the IDs of the KYB and Marzocchi parts. I too bought KYB bushings but after being trimmed to height (15mm instead of 20mm) the KYB bush was sloppy around the PFP piston.
I did mine successfully last night, and I'm confident its corrrect. Please be carefull with this stuff, think about how you retain it so you don't break something or slip and hurt yourself. It takes a little arm strength but certainly no straps!:eek:
Filled cartridge with 210 - 215 cc, did a preliminary bleed by cycling the damper rod with the rebound clicker open.
Adjusted oil level to 125 - 130mm with damper rod extended, and let sit for a half hour. No more oil or things wil be VERY difficult.
Grease orings on comp/PFP assembly, oil on bushing. I dipped the comp piston in oil and shook it around to get some of the air from under and behind the shims out.
Insert the assembly slowly into the cartridge. You will notice a huge distance from the bottom of the comp assembly cap to the cartridge cap when the the lower PFP oring engages the bore and resistance starts. This is mostly from a large slug of trapped air.
Keep light to moderate pressure on the comp assembly, and slowly raise the damper rod with your other hand. While doing this, wiggle the comp assembly side to side slightly. You will hear a short hiss as air escapes between the lower oring and PFP bore in the cartridge. The idea is to keep the lower PFP oring right at the very edge of the bore, and increase the pressure by raising the rod. Its important to maintain pressure on the assembly so it does not draw any air in. Once you hear air escape the PFP oring will seal, so lower the damper rod while keeping pressure on the assembly. Repeat, it should take two or three cycles before no more air is able to be purged.
Now notice how much closer the assembly cap is to the cartridge because most(not all) of the air is gone. Now compress the PFP spring and use your cap tool to start the threads. What I found to be easiest and safest is to hold the cartridge in the vise using a 45mm seal driver as a guide, with a piece of polyethelene under it(you could cut a milk jug too). This is slick especially with oil and allows you to just compress and hold the cap in position, while turning the cartridge body from the bottom with your other hand. That way you do not have to release pressure and regrip the tool after a partial turn and wonder if you got the threads started.
Snug the comp assembly down. Put a rag on the bench to protect the rebound adjuster body/threads. Compress the cartridge slowly, you should have full travel and it should extend completely. Each cartridge will likely extend at different rates, and the PFP will be at different positions when viewed through the 5mm holes. Do this several times, adjust the comp and rebound clickers to 2 clicks out from full hard, and do several times more. This will purge oil through the shim stacks and any small bubbles out. Open the clickers and let the cartrides sit for a few minutes.
At this time all seems well but its not, there is a lot of air and excess oil to purge. You will notice that it does not purge through the PFP shaft recess at full compression. Why? I beleive its because you are fighting stiction of the PFP piston and orings, you are losing PFP travel from this while the trapped air is compressing, and the inner seal cannot reach the shaft recess. What you must do to get around this is compress the cartridge RAPIDLY, as fast as you can until it bottoms. Transient force overcomes stiction(think impact tools). When you do this fast enough you will hear a gurgle from the top as the PFP clears the shaft recess and vents. Do this several times until it no longer vents, mine vented twice. Dump the few cc of purged oil from the top of the cartridge through the holes.
Now, both cartridges should acheive full travel at the same force and extend at or very close to the same rate. Looking through the 5mm holes, the top edge of the upper PFP o-ring groove should just be visible at the bottom of the hole when the cartridge is fully compressed. Now your done, each cartridge has the same amount of oil and no trapped air.
So, you guys that are drastically overfilling and hoping to purge it out are killing yourselves for nothing. It should not be and is not that hard when done as described. The 210 - 215cc range is just enough to allow a purge as described. But, just filling with 210cc and closing it up is no good either. It may purge by itself while riding but I'm not sure if you can or want to bottom it that hard.
Back together it feels really nice with the bounce test, increased rebound is evident, and I suspect it will be more compliant with the correct cartridge pressure and valving tweaks. Hope to get another part I'm waiting on so I can ride it and report.
Great report GMP, I think this explains the reason why there's differences from fork to fork.
This thread also made me realize how important it is to service any suspension after the initial break in. If nothing else at least to change the oil.
So without reading the entire thread, what are you guys using for replacement springs? I was told YZ250 springs last night when I bought the bike. I am not opposed to going that route, just wondering if anyone had any other suggestions.
So without reading the entire thread, what are you guys using for replacement springs? I was told not YZ250 springs last night when I bought the bike. I am not opposed to going that route, just wondering if anyone had any other suggestions.
FIFY. The YZ springs are 250mm long, the stockers are 275mm, and you have two clip positions left (10mm of adjustability). KYB makes springs that are 270mm long and these can be used without an additional preload spacer.
Awesome. I think you told me that last night but I was too excited and trying to fight off the cold that I am suffering with now to remember.
I have a rear spring to put on, now to get fronts. I will probably race it as-is this weekend and deal with the suspension in the next week or two.
Mine work pretty good, got about 30 miles of hell in today. Still a serious feel, but rebound control is much better now. Not much fast stuff where I ride local but there is a sand pit area with a short whoop section, and the fork is like butter! I can't wait to race this thing in south Jersey. I'm going to play with the PFP now that I know the fork is filled and purged correctly.
Ok so Im looking to setup my forks. If i send it off to a suspension tuner what should i ask for if i want it setup for trail riding Rocky stuff and typical single track stuff? I weigh 90kg without gear. Any suggestions?
You just said it! Add your ability too. Try and find a tuner who has had these apart. Actually from what I found in the valving, not a big change for a light rider unless your really fast. Adding rebound and getting rid of the free bleed got mine real close. Service and correct fill/bleed have a lot to do with it as well.
I have been playing with my forks before sending them off to make sure i need to have any changes and here is where im at..
I am at 20 clicks R
3 clicks from softest C
Standard pfp (Not sure where as i have not played with it)
I like the forks where they are but i am getting the CLUNK others have mentioned in big whoops and g outs. If i slow the rebound im losing feel in the front end as in its "dozing" or washing out type of feeling.
So should i leave the standard fork springs and just get a service and get extra oil (Evan said that is why they clunk as there is not enough oil and the pfp is bottoming out. I think thats what he meant :confused: ) or go for springs to my riding weight 95kg?
Cheers Nato
Mate ,
I had mine done and it was 30 mm different between forks in oil height.
The tuner put heavier oil in and removed the free bleed shim and did other valving also.
This has fixed everything and the forks are now awesome. I have rebound adjustment ( finally) and have actually upped the compression too.
PFP is at 2 at the moment.
I am about 85-88 kgs and the tuner checked it all out and set the sag for me .
He reckons the springs were fine and they do feel good now.
Cheers Mark
20 clicks out on rebound? Wow, I'm at 5 out after removing the bleed shim and changing the stack. I plan to stiffen the stack even more. There is also a bleed shim on the midvalve stack, that and the rebound stack bleed make the adjuster virtually unusable. The best the fork has felt was after the bike sat outside overnight in freezing temps. Since oil viscosity affects rebound a lot more than compression this is telling me something.
Mine have been pretty good after removing all the free bleed(compression also), and changing the comp stack to a 2 stage. I'd still like to fine tune it but so far there have been no 8mm ID shims available in the larger diameters. Follow the cartridge fill and bleed procedure I did, it seems to work out very well.
One thing that is different about these forks compared to a KYB SSS is the amount of cartridge spring preload, even with the PFP set full out. Thats why a KYB is easier to put together, there is virtually no preload on its ICS spring at full extension when filled and bled properly. The Zoke has 7mm on a 20Nm spring with the PFP full CCW. I think they did this to address cavitation in the first stages of travel. What it does do is slightly add to the overall spring force and preload of the fork. I always thought that the fork felt like it was sprung stiffer than it actually was. I'm going to try dropping the main spring preload way down to 1 - 2mm, and perhaps going up on spring rate. Then the PFP can be used to increase overall preload if desired. As it is now there is a huge range of adjustment in the PFP that is not used. This should get the fork to settle a bit more in turns and I'm hoping make the steering lock issue less noticable.
Glenn,
I am going to have Hall's respring the bike for my riding weight @ 250 while they are in there is there anything I should have them do, I saw were you tweeked the rebound, did you just stiffen it up. I make such a bloody mess working on forks that I hate to dig into these, I was barley able to keep track of all the parts and shims on my 45s (would have been lost without Bret's and yours help).
These are not a good fork to learn on. I removed the free bleed from all three ckts, stiffened the rebound stack, and made the comp stack a two stage. I left the midvalve alone for now. Not much else I could do to the compression without those huge 8mm ID shims. Proper fill and bleed and it should be good. I would think for down in TX where its open and fast you will love these forks, they are in another league than the 45s.
Sent from my C771 using Tapatalk 2
