I have an Amsoil account and saw they only had a 5 and a 10 weight.
You can mix 5W and 10W (same brand) in order to archieve a custon oil![]()
And what to run in shiver 45s prey tell?
LUCKILY there is no easier fork to work on, you need two specialty tools that every yz from 2005 on needs too, the compression unit removal octagonal socket and a universal Showa kyb fork cap wrench ( 40 bucks the lot MAX) you also need to be able to set the fork oil height, motion pro or race tech make good tools for cheap for this, or you can make something homemade with a ruler and a syringe. You need a measuring jug and a fine measurement vessel like a cheap mm rain guage from a hardware store or a 500 mm measuring tube of the net for fifteen bucks.
Then you need a cartridge holder, 2 by 4 ( forbeetwo in oz) pine, drill a 1"1/4 hole and cut down the middle. Done.
All I did was loosen the cap on mine so far said:Correct, the small octagonal thingy is to open the cartridge.
Cheers!!
Pulled mine down today and was a little surprised to find a few things.
The inner fluid on both forks was 210 which was good but the left hand side oil was dirty whereas the right side was clean?
The outer fluid was 250ml on the left fork and 240 on the right???
These forks had bugger all bottoming resistance and also had the dreaded clunk , which is why I delved into them.
I also found an alloy spacer? loose on the internal part.
The spacer is located at the bottom of the internal cartridge and is near the point where the two pieces meet if the shaft is compressed all the way in. It is held there loosely by a circlip?
I did not notice this on the first leg.
The PFP adjuster was loose and the spring had heaps of room to move around( about 3mm). I tightened this up and the spring had a little bit of slop still but seemed good.
When redoing the comp adjustments I noticed the last fork I did only had 16 clicks instead of about 24?
I refilled both the inner and outer cartridges to the specs( 210 and 340ml).
I have not had a chance to test the bike as it is late here but I will give it a go tomorrow.
Cheers Mark
Watching thisSus it out Mark
Seems somewhat strange and I agree thats a load of oil to lose. I've dropped a capful of suspension fluid on the workbench and it goes a fair way..
Also, whats everyone using for bushings/seals in these legs? Any crossovers? The stock ones are tight. Mega stiction, especially if the bikes been sitting for a few days.
